Author Topic: BSP100 mosfet blows open, not short  (Read 1375 times)
Online CirclotronTopic starter
« on: September 19, 2019, 11:14:15 am »
Using a BSP100 mosfet and several times because of equipment installation errors the mosfet drain get +12V battery applied and so when it switches to ground it dies. The thing is, gate is shorted to drain but drain-source is open circuit. I thought that’s a bit unusual. Seen it happen several times. Bonding wire failure?
Offline fourtytwo42
  • Interested in all things green/ECO NOT political
Re: BSP100 mosfet blows open, not short
« Reply #1 on: September 19, 2019, 11:42:55 am »
I used to use these a lot and had trouble with failures on some prototypes, eventually turned out to be ESD damage during assembly!
Offline Miyuki
  • Country: cz
    • Me on youtube
« Reply #2 on: September 19, 2019, 05:50:10 pm »
As most today low Rds MOSFETs datasheet have line with: "current rating limited by package"
Bond wires are weak link, they can blow even sooner than chip is busted, but their melting will kill it as it produce hot spot
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: September 19, 2019, 06:05:15 pm »
Step 1. Die overheats.
Step 2. Die melts, becomes 3-way short.  Gate oxide is disturbed, junctions are melted together.
Step 3. Fault current ensues.  Melt spot becomes vaporization spot; die surface and bondwires evaporate into plasma.
Step 4. Supersonic plasma ball builds pressure until the package is fractured, releasing a sharp "CRACK" into the surrounding air.
It would seem your example went through at least steps 1-3, and had little gate current to vaporize that bondwire, leaving a 2-way short.
Drain will almost never become open, because it's the tab the die backside is glued onto.  source bondwires will vaporize instead.  Gate may become disconnected due to the cracked package if step 4 is reached, or remain connected after all.
Note that during steps 3 and 4, the transistor becomes an all-way short, exposing gate and source circuits to some fraction of drain circuit voltage.  This can destroy e.g. gate drivers, even behind a coupling transformer, even if the device ends up a three-way open.  Transients are not to be underestimated!
I've seen a lot of "silent" deaths in my work.  Steps 1-3 are followed, but there isn't enough energy available (or the device doesn't fail in a low enough resistance mode) to blow open the resulting short.  A bit annoying for fault finding, but, it doesn't leave shrapnel which is nice, right?
Seven Transistor Labs, LLC
Offline TheHolyHorse
  • You don't need to be confused, just understand it.
« Reply #4 on: September 19, 2019, 06:30:07 pm »
I think I prefer the shrapnel over more complicated debugging ;D
Offline james_s
« Reply #5 on: September 19, 2019, 07:42:47 pm »
I've seen blown bond wires a couple times but it has been rare for me.
I'm all too familiar with shorted mosfets causing a cascading failure. I had a washing machine motor controller that blew up every IC on the board including the ASIC running the whole show. It's the reason I'm not really a huge fan of non-isolated gate drive ICs.
Offline Miyuki
  • Country: cz
    • Me on youtube
« Reply #6 on: September 19, 2019, 07:51:16 pm »
I know some people even using failed IGBT modules with parallel chips for hobby use
Most times is only one chip shorted and bond wires can be blown by big capacitor
So rest of module can be used at appropriate lower powers
Offline jbb
« Reply #7 on: September 20, 2019, 01:26:54 am »
I once blew the silicone potting gel out of a 1700V 1200A IGBT module. It was very loud and messy. (I was glad to be behind a blast shield and wearing earmuffs for that testing.)
ABB I think went through a lot of trouble to develop special IGBT packages that were guaranteed to fail short. I think they moved away from bond wires to outright compressions springs.
« Reply #8 on: September 20, 2019, 03:10:28 am »
What would be the benefit of failing short? I would have thought that failing open would limit the damage, especially in a half bridge leg.
Offline duak
« Reply #9 on: September 20, 2019, 03:27:39 am »
Circlotron makes a great point - is a short better than an open?  Would it be better for the drivetrain in an auto to lock up or free wheel when something fails.
In the days before T0-247 (and similar) packages I was developing a PWM servo using TO-3 MOSFETs.  Something went wrong and an internal arc was struck between the case and the source pin or bonding wire.  It burnt a 1mm hole in the steel case before shutting down.  I didn't do a post mortem on the part (an IRF340) so I don't know if it was a manfacturing defect or maybe just a bonding wire failing and springing up to the case.
Offline jbb
« Reply #10 on: September 20, 2019, 03:40:27 am »
Yes. Sorry.
The ABB application was in High Voltage DC power converters, where you connect a whole heap of 6.5kV (or thereabouts) in series to make a composite switch rated at 150 kV at a thousand amps or more. An open circuit would be Bad News here because it would arc like nobody’s business. So instead they use more switches than necessary and accept some short circuit failures.
The converters include special gate drive and snubber systems which distribute the off voltage evenly across each switch.
Offline T3sl4co1l
« Reply #11 on: September 20, 2019, 07:18:21 am »
I got a good one for you, yesterday -- I made a control board using a PWM chip (internal 5V reference), and the inverter with a Hall effect sensor for power measurement.  Well, in one test I grenaded the inverter; as it happens, the transistors failed silently (stage 3 failure), and fault current flowed from the filter caps into the transistors through the sensor.  The sensor is the only part that exploded!  Conveniently, said sensor was powered by the PWM chip's 5V reference (the circuit is 12V otherwise), and it happened to take out both!
Offline james_s
« Reply #12 on: September 20, 2019, 11:50:33 pm »
That's something I have always liked about power electronics, when something goes wrong it tends to be pretty exciting! Unfortunately it also tends to be expensive.  :(
Offline jbb
« Reply #13 on: September 21, 2019, 04:22:37 am »
Many's the time at my current job where I've wished for a nice clean 'bang' type fault, instead of the elusive intermittent bastard type fault.
On the other hand, I don't have to fill out safety paperwork, and the last thing to make clouds of smoke was the kitchen toaster.
« Reply #14 on: September 21, 2019, 05:22:35 am »
If only the nice clean ‘bang’ you speak of was limited to the power device instead of snaking it’s way through the board.  :palm:
