Author Topic: How to control the output of a Current pump with the help of an audio DAC  (Read 5496 times)
Offline Vovk_Z
  • Country: ua
And I don't see any capacitors in power lines.
Offline ali_asadzadehTopic starter
eagle eyes, the problem solved! thanks ^-^
How much Cap do you recommend for 30A?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Guys do you have any idea about AM modulation, is there a clever way to implement it in this design? so I can get ride of range resistors or digital POT IC's.
Offline Vovk_Z
  • Country: ua
>= 47 uF. That's not a strict science, I guess you may try anything  like 0.1 uF and larger to get rid of power wires inductance.
Offline David Hess
  • DavidH
It depends on the required ESR.  22 to 100 microfarads per amp for aluminum electrolytic capacitors is a common starting point.
The following users thanked this post: ali_asadzadeh
