Author Topic: Socket Wire connector suggestions  (Read 270 times)
Offline Revky27Topic starter
« on: December 18, 2024, 06:44:16 am »
Hi All,
I want to mount some small temperature sensors (transistor type in an enclosure). I want these sensors to be removable hence I plan to use a tiny connector. On the other side I would like to have a wired socket fixed in a plastic holder with wires already routed hence I can swap the sensor.
Does anyone know of any family which offer wired sockets (with crimps for easy assembly and avoid soldering) to PCB plugs? Ideally, I need only 1x2 with small pitch 1mm or 1.27mm
Thanks
Offline jbb
Re: Socket Wire connector suggestions
« Reply #1 on: December 18, 2024, 08:31:54 am »
It’s bigger than you’d like, but how about Molex Micro-Fit?
Offline Whales
    • Halestrom
« Reply #2 on: December 18, 2024, 10:02:41 am »
Are you specifically after "panel mount" options?
I'm not sure how that mixes with no soldering, unless you're after screw terminals on inside to screw the legs of your temperature sensor to?  Can you draw a picture of approximately what you're after?
I was originally thinking of suggesting 3.81mm pluggable terminal blocks, but they require soldering or a PCB on the inside:
https://www.lcsc.com/product-detail/Pluggable-System-Terminal-Block_DEGSON-15EDGRM-3-81-02P-14-00A-H_C507015.html
https://www.lcsc.com/product-detail/Pluggable-System-Terminal-Block_Ningbo-Kangnex-Elec-WJ15EDGK-3-81-2P_C8466.html
https://www.lcsc.com/product-detail/Pluggable-System-Terminal-Block_DORABO-DB2EVC-3-81-2P-GN_C395686.html
https://www.lcsc.com/product-detail/Pluggable-System-Terminal-Block_Ningbo-Kangnex-Elec-WJ15EDGRC-3-81-2P_C8387.html
« Reply #3 on: December 19, 2024, 07:32:45 am »
The problem are those options are too big.
If there was a molex-micro fit with 1.27mm pitch would be ideal :D
