Hey,
I want to divert the power flow between two lines as shown in the figure.
My question is, Is it possible to divert the power flow just using toggle switch? Because I am not going to switch between the lines when it is operating. I only switch it when the circuit is off. I am going to do it on PCB. Do I have to worry about any ratings? I thought of using relays but anyways it takes lot of space and also as I said I am not going to do the switch it when the system is working. Please let me know if its possible or not. If its possible what are the factors I should worry about. Thanks.
