I'm using a PZT2222 to drive a "5V active beeper" that I bought off eBay. I recall using these in the past and didn't notice much of a kick back when turning one off, but I just took a look at it with my scope and it shows a 200ns pulse of 63V. The PZT2222 data sheet says the CE voltage max is 40V. Does this mean I need to use a reversed biased diode? Is 200ns short enough that it isn't necessary?
