Here's an updated copy of the schematic; the gain control wiring has been corrected, and the diode part number has been corrected. Those were napkin to jpg transcription errors; sorry about that.
I've been reading through the comments posted and I've got to say it's been very informative. I see opinions masquerading as facts being spouted by people who clearly do not understand how this amplifier works.
It is what it is; a very clean amplifier that's simple enough to put together on the kitchen table. Old school parts in places - because they do the job and are cheap. Enough output power for a home stereo system. If you want to substitute the opamp or driver transistors, feel free - the last of these I built used 2N2905 / 2N2907 for the drivers. I'd keep the same output transistors, though - they're very well suited for the job.
For those who have batted the input resistance issue around the block a few times - electrolytic capacitors in the signal path are evil. By keeping the input resistance high, a 0.1uf input coupling capacitor can be used. Does this increase the opamp's input noise? Yes, but it's swamped by the input signal so it's not really a problem at all. And as a bonus, the input capacitor / resistance provides a HPF at the input.
Those who say opamp based audio amplifiers aren't much good are mostly correct. There's been far too many misbegotten examples, but that doesn't mean they're all bad. Sometimes things just work and the whole is greater than the sum of the parts. This is an example of what happens when it goes right. No, it didn't just happen by chance, many hours / days were spent testing various variations and permutations until a stable, minimum cost design was finally arrived at.
