Oups, i forgot about the "-" in the values, i fixed it.
This is indead my own design, but i have tried to follow the datasheets guidelines to the letter. The -12V rail is the only one not working.
As for the voltage at the FB pin, measured at the C8 cap, it was -33uV when disconected from Vout. I found no shorts to ground.
When connected to Vout, the voltage darectly at the Sense pin is as -14.86V, but at the Sense side of the R6 resistor is -29uV. And the C* cap remains at -33uV.
