Author Topic: DIY STM32 flash programmer with FT232R  (Read 2601 times)
Offline BoscoeTopic starter
« on: September 08, 2015, 11:25:31 am »
So i'm doing a programmer to make a batch of MCUs a bit easier to program with an automated process (program). However I'm having trouble with the UART comms. I have set all the baud rates etc. to the correct values and i'm sending the commands described in the boot loader documentation from ST but I get strange or no no response. First off the baud rate the boot loader is sending seems to be faster than the max of 115200 and some times I get one, two or three bytes sent back from the boot loader when I should be getting fifteen for the command I'm sending.
This is the document I've been using http://www.st.com/web/en/resource/technical/document/application_note/CD00264342.pdf
If anyone who has experience doing this could give me some pointers?
Thanks
Online Psi
Re: DIY STM32 flash programmer with FT232R
« Reply #1 on: September 08, 2015, 11:28:59 am »
I use this linux stm32 flashing tool to program some STM32F1 chips and it works fine.
http://sourceforge.net/projects/stm32flash/
You could look at the code or datalog what it sends and compare that to your app. It might give you some clues.
« Reply #2 on: September 08, 2015, 03:23:01 pm »
Thanks. I found what it was. I didn't initialise the boot loader, i just started writing commands to it.
