Author Topic: Need to find a Male connector  (Read 5564 times)
Offline GrayfoxTopic starter
« on: August 17, 2014, 10:18:05 am »
I need to find a male connector that is.
11mm wide X 8mm tall X 15mm deep with 3mm pin pitch
I have looked on digikey and element14 but I cant find it
« Last Edit: August 17, 2014, 10:19:53 am by Grayfox »
Offline ovnr
  • Country: no
  • Lurker
Re: Need to find a Male connector
« Reply #1 on: August 17, 2014, 12:00:55 pm »
Well, try looking closely at it - a lot of connectors have a (small and faint) manufacturer logo or name. Makes it easier to narrow it down.
« Reply #2 on: August 17, 2014, 12:13:34 pm »
It doesnt have any markings on it
It is on a car
Offline Gribo
« Reply #3 on: August 17, 2014, 12:37:44 pm »
It looks like Molex MX150 series, however I would check the usual suspects (Delphi, Tyco, Molex and FCI). What car is it?
I am available for freelance work.
« Reply #4 on: August 17, 2014, 01:42:49 pm »
Civic hatchback 8th gen.
Offline Richard Crowley
  • KJ7YLK
« Reply #5 on: August 17, 2014, 02:42:12 pm »
Forget finding it via typical electronics sources.  The automotive industry has a whole separate ecostructure.
Go to a Honda dealer or "junkyard" that specializes in Hondas.
Offline aargee
« Reply #6 on: August 18, 2014, 12:48:05 am »
Yes, what Richard said.
Not easy, not hard, just need to be incentivised.
« Reply #7 on: August 18, 2014, 04:53:11 am »
I can understand automotive connectors are unique but i was hoping to find a compatible connector, i found a connector for the internal fusebox
Offline Alexei.Polkhanov
« Reply #8 on: August 18, 2014, 06:53:56 am »
Probably one of auto parts stores will be best bet to find it, if not why not simply cut it off and install similar connector in place for which you have mating jack? It is just two crimps inside right?.
  • KJ7YLK
« Reply #9 on: August 18, 2014, 07:16:28 am »
It just seems perverse and inexplicable that you seek it in a place where you are unlikely to find it,
while apparently rejecting the most likely source, the auto (specifically Honda) infrastructure.
« Reply #10 on: August 18, 2014, 08:56:37 am »
Honda dont sell the connector by it self.
Offline miguelvp
« Reply #11 on: August 18, 2014, 02:29:15 pm »
Of course they do, you just have to find the right part number. On the service reference manuals for repair shops they have to have all of their parts listed.
You might have more chances to get access to the on the European links from the manufacturer, I was able to find detailed reference manuals for my engine with all the parts and bits of a toyota celica engine. for $15 week access or so, long forgot the link since I downloaded every single pdf file during that day :)
« Reply #12 on: August 18, 2014, 02:41:28 pm »
The part i need the connector for is apart of part number 2.
http://www.lingshondaparts.com/honda_car_parts_selection.php?block_01=17SMG601&block_02=B__5210&block_03=16528
An image of the part
Offline miguelvp
« Reply #13 on: August 18, 2014, 03:40:14 pm »
Seems they use it on other applications.
http://www.ebay.com/itm/3rd-Brake-High-Mount-Stop-Light-for-06-11-Honda-Civic-EX-Coupe-/310801003675?pt=Motors_Car_Truck_Parts_Accessories&hash=item485d2ef49b&vxp=mtr
So do you need the wiring harness connector side or the one depicted in that assembly, as shown here:
If it's the assembly that image you posted is from an ebay listing that has the whole assembly for $33
« Reply #14 on: August 18, 2014, 05:09:43 pm »
Looks like plastic housing of connector is custom, made to mate with "another half", but inside I see standard "quick connect quick disconnect" or "faston" connectors for which it is easy to find second part like here on Digikey:
http://www.digikey.ca/product-detail/en/2-520193-2/A27806TR-ND/289253.
I am pretty sure you can find plenty of connectors like this without housing around the car. They come insulated and non insulated, in standard withs 6.25mm, 4.5 mm etc.
« Reply #15 on: August 19, 2014, 01:06:07 am »
Yeah, i need the male connector.
I made a custom center brake light
