Author Topic: Cable strain relief for off-the-shelf enclosures?  (Read 2689 times)
Offline george gravesTopic starter
« on: August 18, 2014, 01:31:04 am »
I'm having a hard time looking for something like this.  I don't really know what they are called - so it's hard to search for.
Basically, need to have some wires exit a standard Hammond type case.  And want to add some "strain relief" - and not just a hole in the case with wires coming out.
I found something kinda close searching for "Sleeved Grommet" - blah - not it.
But it's not exactly what I was looking for.
I was looking for something a lot like this:
Anyone point me in the right direction?  What term should I be searching for?
They should be super cheap - I would think.  Something like 100 for $10-$15 USD?
(And be installed like a grommet where it get locked into a hole drilled into the case.)
« Last Edit: August 19, 2014, 08:57:33 am by george graves »
Offline Rufus
Re: Cable strain relief for off-the-shelf enclosures?
« Reply #1 on: August 18, 2014, 02:27:44 am »
They are called grommets, sometimes sleeved grommet, and sometimes strain relief like this one
http://www.newark.com/hellermann-tyton/hv2228-pvc-bk-d1/strain-relief-pvc-5-6-5-5mm/dp/93R5141?ost=1827047
The data sheet for that part shows a small range and calls them "Bend Protection Grommets".
« Reply #2 on: August 19, 2014, 08:57:07 am »
Yes, as I posted.  "Sleeve grommets" are a close thing - but not quite.
Bump!
Offline GeoffS
« Reply #3 on: August 19, 2014, 09:37:09 am »
A search for "strain relief grommets" turns up a few that match your photo.
