I have recently acquired a Samsung front loading washing machine. It was working fine except for the door latch mechanism was broken so the previous owner had used huge self stick velcro straps to hold the door shut... anyway I only wanted the guts, the rest I scrapped minus the drum for a fire pit. My question is, On the motor there is the usual 3 pin(3 phase) power connector and a rotor position sensor connector. The odd thing I can't find info about anywhere, is why the hall effect sensor connector is only 4 pin instead of 5 as it is on all sensored brushless motors I've seen? Normally the RPS/Hall sensors have 5 wires. One power, three for Hall A B C, and one ground. Neither a controller I bought nor one I built will run this motor, however I haven't tried using either. I have the control board and the separate inverter board which the motor and sensors connect to. I want to build a controller for this motor or even better just use the factory inverter board (fed with my own control signals) to run it.. any information or advice would be much appreciated. Once I understand the sensors, making a controller will be straightforward. I could of course tear into the sensor module and see the sensors physical form and layout but I want to avoid damaging anything. Besides, opening it up to basically find it has two hall sensors instead of 3, still tells me little about how to drive the motor. The pin identifiers for the sensor cable on the board and in the very simple block diagram in the technical info pamphlet simply say, Vcc, U, V and GND. I'll include pictures of the motor, the 4 pin sensor plugs and the factory control board. The factory motor control inverter board has (from left to right in the picture) 2 pin molex power input, 3 pin molex power output to motor, 4 pin molex hall sensor feedback, and a 3 pin molex control signal input from the main control board.. No set plans for a use yet but I'm looking forward to the design challenge. Might eventually turn it into a generator if I can't find a good use for it. Thanks for sharing your time and knowledge. -Rex-
