Author Topic: Plastic support for TFT displays  (Read 2396 times)
Offline prasimixTopic starter
  • Country: hr
    • EEZ
« on: August 04, 2016, 08:18:23 am »
Does anyone have any idea where to buy this plastic support for TFT displays (or order custom one in accordance with given specification)?
Many thanks in advance.
Offline dansku
  • I make things
    • Personal Blog
Re: Plastic support for TFT displays
« Reply #1 on: August 04, 2016, 10:43:30 am »
How many do you need?
If its just for testing, you could always 3D print it :D
  • Country: hr
    • EEZ
« Reply #2 on: August 04, 2016, 10:49:59 am »
You're right, but lets suppose that a small series is required (i.e. 100 pcs) or even more over time if the displays with same dimension is used in more products. I was thinking about laser cutting but it has to be 10-11mm high, not sure if cheap laser could cut so thick material.
Offline TerraHertz
    • It's not really a Blog
« Reply #3 on: August 04, 2016, 01:56:50 pm »
Can't you just use 4 plastic posts? Looks like the one in the pic only has the cross pieces to make the 4 posts into one piece, for easier assembly.
  • Country: hr
    • EEZ
« Reply #4 on: August 04, 2016, 02:01:18 pm »
Sure I can, that is what I'm using now. I just wondering if someone manufacture such plastic support since it could be easier (faster) for assembly and possibly it could provides a better mechanical strength.
Offline CM800
« Reply #5 on: August 04, 2016, 02:19:47 pm »
For 100pcs, I'd say keep with what you are doing and glue some laser cut plastic strips between them!
1000pcs+ Injection mould. .... or extrude and cut?
  • Country: hr
    • EEZ
« Reply #6 on: August 04, 2016, 02:25:28 pm »
:) sounds realistic, but I'm still hoping that someone already had some experience with such item. Or that is really a genuine innovation that comes from Mikroelektronika and not just a common accessory for displays available somewhere in China?
Offline NottheDan
« Reply #7 on: August 04, 2016, 07:26:21 pm »
Wouldn't that just be a custom injection moulded job? Cheap in volume but the cost of the mould makes low-volume orders rather less affordable.
