For a voltage source, current feedback control can be an inner loop of the voltage controller.
The voltage regulator generates a current reference, and the current controller generates the duty-cycle.
Both controllers have limited output.
That's what is usually done in variable voltage supplies with variable current limit. They can act as both voltage sources (until the current limit is reached) and current sources (until the voltage reference is reached), following the limit which comes first.
