But those aren't IGBTs...
That power level is perfectly reasonable to build on PCB. Pay attention to parasitics, as trace length will be in the 20-200nH equivalent range, depending on how good your layout is. (Hint: an optimal amount, rather than a minimal amount, is desirable, especially with a snubber in place.)
How many transistors are you intending on using, and in what configuration? What is the source? What is the load? Do you need isolation, gate drivers, EMI filtering or shielding, ... ?
