2.) Is there a recommended location within the oven to place the board? My naive inclination is the center of the oven.
3.) Same as #2, but for the thermocouple. Should it be installed from the top or back? Centered or to the side? Does it matter?
Well, in general center the board between multiple heating elements. Closer to the element gets hotter.
I have never gotten a thermocouple in air to work. I've burned several boards. What I did was get some micro-sized
thermocouple extension wire, stripped and twisted the ends and poked it into a plated through hole in one of the boards. That way, the thermcouple reads the actual board temperature.
I also use a ramp and soak temperature controller I got on eBay. These allow you to program linear temperature ramps and temperature holds. I ramp to 180 C for a couple minutes, hold at 180 for one minute, then ramp to 230 C in a couple minutes, hold for one minute and cool to room temp.
I use this system to reflow from one big board up to 8 small ones at a time, and have done over 2000 boards with it.
I got a large GE toaster oven with 4 heating elements. Two are above the rack, running left to right, toward the front and the back. Two more, same arrangement, below the rack.
Jon
