Author Topic: Building a RGBW Controller with RF remote control  (Read 736 times)
Offline PinheadBETopic starter
  • Pinball Freak
« on: January 13, 2019, 05:37:01 pm »
I bought a cheapo kit including an RGBW LED strip, a controller with its 40-keys IR remote control and a power supply.
I installed it behind my TV, powered it up and....... it worked as intended !  :-+
I was happy and looking forward to a good TV evening  :popcorn:
And that was when the sh!t hit the fan: I turned on my WD TV Media Player, and... oh surprise .... the remote control of my WD TV was also commanding my LED strips  :wtf:
The only workaround I can think of is to replace the controller and its RC with another one using a RF remote control instead
But looking online for the available Chinese stuff, I didn't find a RC model which suits me: I don't need multi-zone control, I don't need all those flashy effects: I just want to be able to control separately each of the four color channels.  A bunch of preset colors would be a bonus but this is not mandatory.
And I did not find it yet.
So, I thought of building one: remote control with at least 10 buttons (ON - OFF - one increase and one decrease button for each of the 4 channels)
Any one would have seen a good design from which I could take some ideas ?
Thanks for your input
Please keep our planet clean
  • Pinball Freak
Re: Building a RGBW Controller with RF remote control
« Reply #1 on: January 13, 2019, 06:22:54 pm »
... which in fact is a 4 channel PWM controller, controlled over a RF remote control
The RGBW strips I use are not the WS2812 type, but have 5 connections: Common Anode, R, G, B and W
Offline nsrmagazin
  • Country: ru
« Reply #2 on: January 13, 2019, 06:31:46 pm »
I can suggest you limit the range of the receiver or transmitter if possible(both is better).  You need to change the location of 1 of the devices and put it as far away as possible and I don't know if they sell this, but a box around the transmitter or receiver will limit its range and point it more accurately. Unfortunately RF hacks are not my specialty so I can't tell you what the box should be made of exactly so it can do the job.
« Last Edit: January 13, 2019, 06:33:18 pm by nsrmagazin »
Hi all!
If you like the post, please press "thanks".
