Author Topic: Will an alternative ic work  (Read 757 times)
Offline NjacksteTopic starter
  • Country: ie
« on: October 25, 2021, 05:44:51 pm »
I need to replace an ltc4054 but my local Farnell/rs don't have it but they have alternatives such as this https://ie.rs-online.com/web/p/battery-management/7328730.
Will this work?
Will any other alternatives that I can get locally work.
Otherwise I'll just get it on AliExpress or eBay
Offline mikerj
Re: Will an alternative ic work
« Reply #1 on: October 25, 2021, 06:55:09 pm »
The Maxim part provides a similar function but it is not pin compatible.
  • Country: ie
« Reply #2 on: October 25, 2021, 08:23:53 pm »
Thank you
Offline wasyoungonce
« Reply #3 on: October 26, 2021, 07:03:33 am »
Many other mfgrs copy ICs and they still retain the core part number...in this case "4054"....so a quick search for "4054 battery management"...finds quite a few with the same foot print.
Looking at LTC4045 datasheet Vs STC4054..only a quick glance...looks pretty good to me as a drop in alternate.   There are others as well....LR4054.   Of course I reserve the right to be completely wrong here! :-//
https://au.mouser.com/ProductDetail/STMicroelectronics/STC4054GR?qs=%252BFmDY%2FmH7Ib7AgzA73nDoQ%3D%3D
https://www.st.com/en/power-management/stc4054.html#documentation
link below downloads a pdf ...sorry best I could do
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjBoYPkwOfzAhVNcCsKHXFvBr0QFnoECAIQAQ&url=http%3A%2F%2Fwww.lrc.cn%2FUpload%2FPDF%2FProduct%2FIC%2FLIB%2FLR4054.pdf&usg=AOvVaw2YbqgKqHWfz1pmum-UUchk
cheers
I'd forget my Head if it wasn't screwed on!
