Thanks for the helpful comments. This project is a bit over my head, but that's how we challenge ourselves. The AC Entry receptacle that I purchased from Mouser includes the common-mode filtering you see in the schematic, so I can't remove that unless I decide to use a non-filtered receptacle. I've made the edits to the series pass transistor bases, and moved the 100A fuse.
I'll do some more research on how to incorporate the inrush relay. I like the idea of dealing that with in the AC entry stage; many viable relay options for that solution. I still haven't been able to wrap my head around the work-flow electrically for that piece of this puzzle.
I didn't know about the mains entry connector, that's cool.
Moving the fuse means that not only is the regulator and the load protected from overload but the small voltage drop the fuse will introduce into the circuit is ahead of the regulator and won't t regulation.
There are a couple of ways to operate the inrush current limiting.
Having the relay contacts on the primary side with your limiting resistor is the preferred way.
How you energize the relay coil can be done with an RC network, and rectified mains to provide voltage like the one I used in my amplifier, or you can drive the relay coil off the unregulated DC, using the inrush resistor on the primary side and the slowly building DC voltage across your caps to pull in the relay contacts after a second or two.
It's times like this that I really wish there were a few mentors locally, that I could convince hanging out in my lab for a couple of days to check my math would be a rewarding and fun experience, haha.
Thanks again... I appreciate all the feedback I can get.
Since the edits I've just made are minor, I won't republish a schematic revision just yet.
Take it a step at a time.
Build up the regulator, incorporate one transistor, use another DC supply to feed it, and put a small load on it. Then add the rest of the pass transistors and put it under the same small load. (a half dozen amps or so) and make sure they are sharing the load.
When you get your big transformer, caps, and diodes you will be ready to go knowing your regulator is functioning properly.
