Author Topic: Arduino Voltage Sense Help  (Read 798 times)
Offline challen908Topic starter
« on: March 15, 2022, 11:30:09 pm »
Hey all,
I need some help, I have a board that runs off a 12V batter and is supposed to sense a car pedal throttle voltage. I have one signal line from the throttle and as the pedal pushes down the voltage on this sense line rises. I have fed this line straight into an Arduino Nano every analog pin and Arduino code will trigger a digital pin at specified voltages between 0.25V and 0.6V, anything outside that range needs to be shut off.
The problem is that when I connect the sense line to the A0 pin of the Arduino I get voltage drop on the sense line itself. For example the sense could be 0.4V and once its connected to the Arduino its drops to 0.25V. How can I prevent this, I can't have any, or next to none voltage drop on the sense line?
I can upload a schematic but the sense line is straight into A0 pin, Arduino is powering from 12V step down just fine
Re: Arduino Voltage Sense Help
« Reply #1 on: March 15, 2022, 11:31:20 pm »
Do I need an op-amp or something to amplify the sense signal? I would like to keep the Arduino so that I can change the range of voltages I want to trigger and read the signal
« Reply #2 on: March 15, 2022, 11:52:58 pm »
« Reply #3 on: March 15, 2022, 11:54:39 pm »
based on the schematic the comparator is not connected, and assume the VIN goes right into the A0 pin on the Arduino with only a pull down 8.25k resistor
Offline ozcar
« Reply #4 on: March 16, 2022, 01:07:20 am »
Do you know how the VIN voltage is produced?
You could try it without the 8.25k pull down resistor, or see what effect a resistor to ground alone has on VIN.
Assuming nothing silly like programming the A0 pin as a digital output set low.
The following users thanked this post: challen908
« Reply #5 on: March 16, 2022, 01:13:18 am »
Yeah nothing silly in programming, and the VIN is coming from the vehicle, going through a potentiometer, and is LVDS, based on my customer’s info, he’s being really vague with me on the source
