Impossible to answer, unless you provide the classes definitions, and their inheritance(s) !
Do these help?
class UserInterface
private:
ControlPanel *controlPanel;
Core *core;
FeedTableFactory *feedTableFactory;
bool metric;
bool thread;
bool reverse;
FeedTable *feedTable;
KEY_REG keys;
const MESSAGE *message;
Uint16 messageTime;
const FEED_THREAD *loadFeedTable();
LED_REG calculateLEDs();
void setMessage(const MESSAGE *message);
void overrideMessage( void );
void clearMessage( void );
public:
UserInterface(ControlPanel *controlPanel, Core *core, FeedTableFactory *feedTableFactory);
void loop( void );
void panicStepBacklog( void );
class ControlPanel
private:
// Common SPI Bus
SPIBus *spiBus;
// Current RPM value; 4 decimal digits
Uint16 rpm;
// Current displayed setting value, 4 digits
const Uint16 *value;
// Current LED states
LED_REG leds;
// current key states
KEY_REG keys;
// number of times current key state has been seen
KEY_REG stableKeys;
Uint16 stableCount;
// current override message, or NULL if none
const Uint16 *message;
// brightness, levels 1-8, 0=off
Uint16 brightness;
// Derived state, calculated internally
Uint16 sevenSegmentData[8];
// dummy register, for SPI
Uint16 dummy;
void decomposeRPM(void);
void decomposeValue(void);
KEY_REG readKeys(void);
Uint16 lcd_char(Uint16 x);
void sendByte(Uint16 data);
Uint16 receiveByte(void);
void sendData(void);
Uint16 reverse_byte(Uint16 x);
void initSpi();
void configureSpiBus(void);
bool isValidKeyState(KEY_REG);
bool isStable(KEY_REG);
public:
ControlPanel(SPIBus *spiBus);
// initialize the hardware for operation
void initHardware(void);
// poll the keys and return a mask
KEY_REG getKeys(void);
// set the RPM value to display
void setRPM(Uint16 rpm);
// set the value to display
void setValue(const Uint16 *value);
// set the LED states
void setLEDs(LED_REG leds);
// set a message that overrides the display, 8 characters required
void setMessage(const Uint16 *message);
// set a brightness value, 0 (off) to 8 (max)
void setBrightness(Uint16 brightness);
// refresh the hardware display
void refresh(void);
