Author Topic: CH340, Oscillator question  (Read 1423 times)
Offline JPorticiTopic starter
« on: December 24, 2021, 04:32:35 pm »
Hi, i'm considering the CH340 as an UART-USB chip (currently using FTDI, planning to switch to MCP2221A) and i have one technical question:
I've skimmed through the datasheet, i see i must connect a crystal, so i assume it can't do crystal-less USB.
However i already have an oscillator on board for the microcontroller an i don't want to place a second one if i can avoid it.
Can i provide the 12 MHz from the microcontroller itself?
Side note, where do you buy yours in quantities like 1000pcs reel or so?
Online jimmc
Re: CH340, Oscillator question
« Reply #1 on: December 24, 2021, 07:56:09 pm »
The CH340C, CH340E and CH340B versions have a built-in clock generator, no external crystal required. See http://wch-ic.com/products/CH340.html.
Jim
Offline oPossum
« Reply #2 on: December 24, 2021, 08:00:10 pm »
CH340B, CH340C, CH340E, CH340K, and CH340N do not require a crystal.
Available from LCSC.
Offline littleboot
« Reply #3 on: December 24, 2021, 08:09:59 pm »
I used the CH340T in my latest project because it was available and cheap and works as expected.
However this chip requires a crystal, I have included my schematic to this post and can confirm it works as expected.
« Reply #4 on: December 25, 2021, 10:10:59 am »
However, according to the datasheet, i cannot use the internal clock if i need the chip to operate over the industrial temperature range, i guess i'll have to try for myself (or not, just use another chip)
