FYI, guessing this is an extension of this thread, for different channels/devices?
https://www.eevblog.com/forum/projects/design-review-help-placing-smps-regs-ref-for-16-bit-dac/For my part, without knowing anything more about the design, I'd give the same advice: REF in the middle, ground plane all around. As mentioned earlier, if REF can be differential, do it; there's nothing wrong with wiring a ground trace on top of a ground plane, just use a net bridge (or 0-ohm jumper, or..) to enforce it in the design.
I did a design with a 24-bit ADC a couple years ago, which seemed to perform at spec. I didn't have the tools or time to fully evaluate it, mind, just that it seemed to give the expected noise levels and gain. (Which also had a switching converter nearby -- for the analog supplies -- adequately islanded and filtered. I did propose ground slots as an option, which the client declined, so solid ground plane it was.)
