Author Topic: Random hack: Human cooling fan from junk.  (Read 6870 times)
Offline zero_budget_techTopic starter
« on: July 05, 2015, 01:04:52 am »
I feel a bit silly posting this, but on the logic that, if it works, it's not stupid, I think it is probably OK.
It is far too hot for me at the moment, and I have better things to spend my money on than a properly designed fan. So I got an old pc case fan, stripped the wires, wrapped the black round the outer conductor of a random 12v wallwart plug, taped it up, then stripped the red, poked it inside, and taped it. Stuck the fan on my desk with blue tack.
It is awesome. I spent nothing, and I am no longer soaked with sweat.
Offline Muttley Snickers
  • Cursed: 679 times
Re: Random hack: Human cooling fan from junk.
« Reply #1 on: July 05, 2015, 01:29:26 am »
It's under 10 degree celsius here, so put us down for two once you have added the heating element.
Muttley
Offline Len
« Reply #2 on: July 05, 2015, 01:47:26 am »
Here is the compatible heating element.
DIY Eurorack Synth: https://lenp.net/synth/
« Reply #3 on: July 05, 2015, 06:08:24 am »
I have been using 120mm mains fans like that for a long time. After a while I added the wire finger guard on the inlet side, got tired of using superglue to stick the finger back together, and broken blades are horrid to balance again.
Offline Richard Crowley
  • KJ7YLK
« Reply #4 on: July 05, 2015, 06:20:28 am »
That is probably a pretty common hack for this crowd.
I have exactly such a rig (including the power kludge) sitting on my office desk.
  • Cursed: 679 times
« Reply #5 on: July 05, 2015, 06:37:38 am »
A candle as the heating element doesn't work either for those about to try, it's 5 degree's here now so hurry up.
Muttley
Offline NiHaoMike
    • Facebook Page
« Reply #6 on: July 05, 2015, 02:18:28 pm »
I actually bought a 120mm Delta fan just for that use. It's far superior to an ordinary desk fan in both performance and efficiency.
Offline rolycat
« Reply #7 on: July 05, 2015, 03:49:02 pm »
When the cheap-arse 6" desk fan I used for solder fume dispersal burned out it was replaced with a 120mm case fan. I made a little wooden bracket which fits the old spring clamp and mounted a power inlet jack and a local switch - power is tapped off the 12V supply for the under-desk lighting.
It's smaller, quieter and more efficient:
Offline void_error
  • I can transistor...
« Reply #8 on: July 05, 2015, 06:18:01 pm »
I've been using these three fans taken out of some old PC power supplies for the last few years during hot summer days (>30C).
They're about 20 years old but they still work. Add DC jack, hook them up and you're done.
« Last Edit: July 05, 2015, 06:20:15 pm by void_error »
Trust me, I'm NOT an engineer.
Offline Deathwish
  • Country: wales
« Reply #9 on: July 05, 2015, 06:56:03 pm »
whats wrong with you guys !. If your going to do it, do it large... better still get a swamp cooler going.
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
« Reply #10 on: July 05, 2015, 07:21:44 pm »
Higher airflow here....
https://flic.kr/p/w9zd2
« Last Edit: July 05, 2015, 07:25:11 pm by SeanB »
Offline rolycat
« Reply #11 on: July 05, 2015, 07:32:59 pm »
Shrimpy.
Now this is a fan:
Offline Deathwish
  • Country: wales
« Reply #12 on: July 05, 2015, 07:37:22 pm »
Thats better, now we are getting somewhere, but will we be able to charge our mobiles with them too.
« Reply #13 on: July 05, 2015, 07:39:55 pm »
Shrimpy.
Now this is a fan:
Yes, buy I did work on the ATAR, and seeing the demilitarisation they underwent it is sad.
Offline Deathwish
  • Country: wales
« Reply #14 on: July 05, 2015, 08:00:17 pm »
Would i get a slap if i said this is the coolest thread today, even if some of the suggestions would send a chill down me if used  :scared:  :-DD...
Offline rolycat
« Reply #15 on: July 05, 2015, 08:42:40 pm »
Actually, I think with all this off-topic hot air the thread's starting to get a bit windy. Maybe we should cool it before we fan any flames 8)
Offline Mr.B
« Reply #16 on: July 05, 2015, 08:48:37 pm »
Very, very common technique...
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #17 on: July 06, 2015, 12:06:54 pm »
i dont think its common for people who can afford multiscreen multidso multigadgets (while they still only have 1 brain to process all) to use junk cooling fan... anyway i use ceiling fan at minimum speed (i hate blazing speed wind blowing at my face) and open window and door and mosquito spray at 8pm - 5am lab hour. free energy cooling air from mother nature.
Offline Mr.B
« Reply #18 on: July 06, 2015, 07:43:52 pm »
"multiscreen multidso multigadgets" is where my money is better invested, rather than purchasing Ferrari branded fans...
  • KJ7YLK
« Reply #19 on: July 07, 2015, 03:57:29 am »
I would have clicked the "Like" button if there was one!   :-+
Offline Mr.B
« Reply #20 on: July 07, 2015, 03:58:49 am »
Thanks Richard.
« Reply #21 on: July 07, 2015, 07:12:08 pm »
Muttley
Mine digital currency! I'm not sure how much power is in the noise made, but if 90% of the input power is released as heat, 10% as noise, then as long as the coins are worth more than 10% of the power used, you are operating at greater than 100% efficiency. Maybe the GPU companies could make some deal with the heater companies for the chips that won't work well enough to sell as computer parts?
Good to know. I guess I just spend too much time around people who would rather throw money at a problem, instead of thinking for a few minutes.
Heh, have you ever actually used one of those? They are awesome. If you didn't already know, they have water jets inside, just enough to make a fine mist. Too bad after the first week some spreadsheet guy took the pipes away.
Offline Deathwish
  • Country: wales
« Reply #22 on: July 07, 2015, 07:14:13 pm »
No I have never tried one, but I can say I have been stood close enough to a number of jet engine exhausts having been a forces child in the R.A.F and played hide and seek with the RAF plod......  :-DD
« Reply #23 on: July 07, 2015, 08:34:30 pm »
That sounds way more fun, but it sounds like a terrible way to cool down. Isn't a jet exhaust hot?
That's like comparing lulabye to deathmetal. Ketamine to amphetamine. TENS to 50Kv.
Offline mikerj
« Reply #24 on: July 07, 2015, 09:04:50 pm »
I'm not convinced that simply connecting a fan to a power supply is worthy of being called a "hack".
If it is then I hacked my phone just now when I put it on charge.
