Please would anyone happen to know whether the 768kHz AKM DACs (specifically AK4493EQ, but datasheets of other models look very similar) can run at 512kHz samplerate? The hex mode would be selected manually, with properly down-scaled 64fs = 32,768kHz MCLK, 512kHz LRCK, 2 * 24 * 512 = 24,576kHz BICK. I do not know if the automatic detection of samplerate multiple (16fs or 32fs or 48fs or 64fs for the hex mode) will work correctly for non-768kHz samplerate, the datasheet does not address such eventuality. Unfortunately the multiple cannot be specified manually for AK4493.
Thank you very much for any help and suggestions.
Best regards,
Pavel.
