Author Topic: Can a diode amplify sound?  (Read 4933 times)
Offline ELS122Topic starter
« on: December 11, 2019, 01:46:25 pm »
can I use a diode to amplify sound? like by driving the cathode?
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Can a diode amplify sound?
« Reply #1 on: December 11, 2019, 01:50:39 pm »
Any unspecified diode type?  Sure, a tunnel diode can.
Seven Transistor Labs, LLC
The following users thanked this post: Yansi
« Reply #2 on: December 11, 2019, 02:18:07 pm »
a 6H2P in particular. it's usually used as a detector in radios.
also while we're on the topic of tube's, can I use a 6k2p tube as an audio preamp, it's meant for RF amplification and I guess it wouldn't work great in a preamp.
Offline T3sl4co1l
« Reply #3 on: December 11, 2019, 02:26:50 pm »
Wait, 6Х2П (6H2P) or 6Н2П (6N2P)?
A diode is not an amplifier.  At best, heater power might be varied to control plate current, but this is far too slow to be useful at audio frequencies (and if the plate voltage and current ratings are too low relative to heater power, it might not end up having any power gain at all).
6K2P ~= EF93 ~= 6BA6, is that right?  I mean, it can be used, but the remote cutoff grid won't do any favors for distortion.  RF tubes do tend to be microphonic, YMMV.
« Reply #4 on: December 11, 2019, 02:37:40 pm »
the 6X2P (in russian) translates to 6H2P it's a double diode, and I wanted to drive the Cathode
 and leave the heaters alone
« Last Edit: December 11, 2019, 02:40:57 pm by ELS122 »
Offline mcovington
« Reply #5 on: December 11, 2019, 03:29:44 pm »
Diode tubes do not amplify.  I am not sure how you envision using it as an amplifier.
I seem to recall that some semiconductor diodes have been used in a roundabout way as (poor) amplifiers by taking advantage of nonlinearity in their characteristics, typically at frequencies too high for other amplifiers available at the time.  (Someone mentioned tunnel diodes.)  Tubes don't work that way.
« Reply #6 on: December 11, 2019, 06:14:03 pm »
something like this example circuit:
Online Yansi
  • STM32, STM8, AVR, 8051
« Reply #7 on: December 11, 2019, 06:15:56 pm »
You troll or what?  ???
Where did you even get that idea?
Offline Ysjoelfir
« Reply #8 on: December 11, 2019, 06:59:17 pm »
If you explain in detail how that is supposed to work I would be very happy.
Greetings, Kai \ Ysjoelfir
Offline SiliconWizard
« Reply #9 on: December 11, 2019, 07:02:19 pm »
Yes. A Gunn diode as well.
For other types of diodes, I don't see how.
Online Yansi
« Reply #10 on: December 11, 2019, 07:07:38 pm »
Every component with a bit of negative resistance on its VI curve can be used to amplify signal, if I am not mistaken. Tunnel and Gunn diodes are two of them.
Online Gyro
« Reply #11 on: December 11, 2019, 07:43:50 pm »
... but in terms of the thread title of amplifying sound, or at least an audio signal. Not a hope.
Best Regards, Chris
Offline emece67
« Reply #12 on: December 11, 2019, 09:01:04 pm »
« Last Edit: August 19, 2022, 02:42:24 pm by emece67 »
Offline bson
« Reply #13 on: December 11, 2019, 11:15:02 pm »
For most diodes, only in the sense that a detector is an amplifier...
Offline mcovington
« Reply #14 on: December 12, 2019, 01:30:07 am »
Why would you expect that circuit to amplify?  It looks like what you would get if you misread the schematic of an amplifier for a filament triode tube and simply put the cathode in place of a grid.
« Reply #15 on: December 12, 2019, 05:21:19 am »
Well if an cathode is positively positively charged than it stops emoting electrons, and if it’s negative it emits electrons. I guess it would probably only weaken the signal but theoretically I think it is possible to drive an audio signal in the cathode as an grid.
Offline Berni
  • Country: si
« Reply #16 on: December 12, 2019, 05:47:23 am »
The problem with your amplifier is that any current pulled down from the output also flows back into the input. Since a diode is a 2 terminal device there is nowhere else that it can go.
Your grid and cathode are basically the same terminal in your diode (heater is not a terminal because the cathode is solid and not a grid). What gives the triode tube its amplification abilities is that the grid and emitter are two separate terminals. When current flows trough a triode it mostly flows between the cathode and plate, very little current makes it to the grid where the input is connected. Its the cathode that is intruding the extra current into the circuit in order to provide more current into the output and amplify power. If your cathode and grid are the same terminal then all the current must come from the input and hence all the power comes from there.
Online ejeffrey
« Reply #17 on: December 12, 2019, 06:30:43 am »
Positively charged relative to what?  This sounds like confusion about "absolute" voltage which doesn't mean anything.  All that matters is the voltage difference between the cathode and anode.  The cathode is always emitting electrons.  If the anode is more positive than the cathode it will attract those thermally emitted electrons, if not it won't.  i.e., it will rectify the signal.  However, it won't add any extra energy.  If you try to bias the anode as you do in a triode, it will then just capture all of the cathode current regardless of small variations in the cathode voltage.
Offline strawberry
  • Country: lv
« Reply #18 on: December 12, 2019, 08:57:04 am »
does he mean diode as triode with direct heated cathode and cathode plate as a grid?
Offline Ysjoelfir
« Reply #19 on: December 12, 2019, 11:32:40 am »
could be, but that would be a pretty awfull triode i assume, since... well... how should the cathode tube that encapsules the heater regulate the flow of electrons, if those pesky little beasts don't even get out of the cathode tube?
despite the cathode material emitting the most electrons being on the outside of the cathode tube...
so we would have a "grid" that is emitting electrons. "grid" current would definitely flow - which won't be a huge problem since the cathode used as the grid will be much tougher than a thin grid, but that thing wouldn't be controllable in a normal way at all.
And we would have a grid made of solid sheet metal. no electrons from the "cathode" (=heater) could pass to the anode, besides from the few that go outside the cathode tube where the heater enters.
but those wouldn't be very regulated from the potential of the cathode at all I assume, but a little bit of influencing coule be possible.
But - I am intrigued now and would love to try this idea at home. maybe this weekend...
« Reply #20 on: December 12, 2019, 09:31:35 pm »
is a diode whit an indirectly heated cathode a triode?? I thought not... it's pretty much like changing the voltage of a diode at one end, which changes it at the other. and if the diode has some gain it could theoretically amplify the signal.
Online Gyro
« Reply #21 on: December 12, 2019, 10:22:24 pm »
... and if the diode has some gain it could theoretically amplify the signal.
The diode has no gain so cannot theoretically amplify anything.
Best Regards, Chris
Online Yansi
« Reply #22 on: December 12, 2019, 10:24:31 pm »
Here you are, a parametric audio amplifier using varactors... and some other interesting stuff. This is what I]d call a diode amplifier.
Courtesy of DL3PB, http://pa1b-qrp.blogspot.com/2012/02/parasaki.html?m=1
The following users thanked this post: Gyro, emece67
Offline daqq
  • Country: sk
    • My site
« Reply #23 on: December 13, 2019, 10:46:14 am »
In short: No.
In long: It might be able to hack together some awful solution with a uselessly small gain.
Online iMo
  • Country: va
« Reply #24 on: December 13, 2019, 10:56:49 am »
TD718 is a tunnel diode, afaik..
You may use a traveling wave tube as well then :)
« Last Edit: December 13, 2019, 10:59:14 am by imo »
