Author Topic: Can anyone help identify these connectors  (Read 881 times)
Offline GreyAreaTopic starter
« on: August 21, 2020, 06:33:37 pm »
Hi,  I'm hoping someone may look at these and recognise them off the bat.
The large connecter I'm reasonably sure is a JST XH, it measures 10x5.8mm on the outside edges and seems to fit a 2.5/2.54 pitch.
The small connector I'm less sure about.   The pitch seems closer to 1.5mm and the outside edges are 8x4.5mm
Thanks
Online coromonadalix
Re: Can anyone help identify these connectors
« Reply #1 on: August 21, 2020, 07:02:43 pm »
seems xh series ??  for the 2st pictures
Offline OM222O
« Reply #2 on: August 21, 2020, 08:26:34 pm »
They're JST connectors, depending on the pitch (spacing between the conductors) it gets a series name like SH or XH. try to measure with a caliper or if that's not an option, take a photo next to a ruler and measure with a software (I personally use fusion 360).
« Reply #3 on: August 21, 2020, 11:10:06 pm »
Thanks, yes I agree the large one does look like an XH 2.54.
Still stumped on the smaller one, as I said, the pitch seems closer to 1.5mm but I've looked though this list up to 2.5mm and can't find a match.
http://www.jst-mfg.com/product/search_e.php?type=1&id=1&page=1
Maybe I should just desolder them and put known ones in.
Offline Monkeh
« Reply #4 on: August 22, 2020, 12:50:10 am »
JST XH and PH.
The following users thanked this post: coromonadalix
« Reply #5 on: August 22, 2020, 11:30:42 am »
JST XH and PH.
PH!  Yes, thank you!!
