Author Topic: Can anyone help me to fix my car remote starter 791 bypass moduel?  (Read 2349 times)
Offline Chevy Silverado 1500Topic starter
 i installed a remote bulldog car starter model RS82 in my 2000 chevy silverado 1500 5.3 lt automatic a year ago along with a number 791 bypass module which has the pass lock 2.
i disconnected my 12volt truck battery. and when i reconnected my battery i went to clear the 791 memory. first i unplugged the 8 pin wire harness connector. then took the number 2 blue wire to ground.
then i plugged the 8 pin wire harness back into the 971 module when the red light came on i unplugged the 8 pin wire harness then i waited 10 seconds while the blue number 2 wire still connected to
ground. after 10 seconds i went to replugged the 8 pin harness back into the 791 module i couldn't get it to seat all the way in. after i removed the 8 wire harness i noticed i bent the number 7 pass lock 2
orange - wire onto the number 8 red wire + 12volt constant pin. i straighten the number 7 orange wire pin back. and then replugged the 8 wire harness back into the module. the red light didn't come on so i
guess i shorted something in the 791 module.
i try ed looking up the numbers 791 and board number CMT - 791A 20: 0060 no luck. can you help me to troubleshoot this and help me to get it working again?
Offline Stonent
Re: Can anyone help me to fix my car remote starter 791 bypass moduel?
« Reply #1 on: November 19, 2013, 04:44:34 am »
If nobody here is able to help, you might also try the EricTheCarGuy forums. Somewhat like EEVBlog but for cars.
