Author Topic: can anyone identify this connector?  (Read 500 times)
Offline xzcvczxTopic starter
« on: October 22, 2021, 06:24:14 am »
before bothering to model and 3d print a female connector for the attached male connector anyone know whether anyone sells female (or pairs) of this connector?
i am not sure if its 4 or 8 pin, as it might just be a common pin for each side of the 4 grooves
please ignore the badly drawn dimension lines, i assumed it would be "good enough for Australia"
Online tooki
Re: can anyone identify this connector?
« Reply #1 on: October 22, 2021, 03:19:46 pm »
What’s it used for? (Like what port is it, on what device?)
Offline Terry Bites
« Reply #2 on: October 22, 2021, 05:57:10 pm »
Image far too small to read dims.
Offline mikerj
« Reply #3 on: October 22, 2021, 06:02:27 pm »
Looks very much like the USB connector on some of the older cheap generic MP3 players e.g. https://www.pchub.com/juye-serial-data-port-jack-usb-special-usb-mini-4p-p114822
You used to be able to get cables from Amazon, usualy called "Mini-B 4 pin" or "Mini 4P", but a quick search didn't immediately throw anything up.
« Last Edit: October 23, 2021, 08:33:04 pm by mikerj »
« Reply #4 on: October 22, 2021, 07:07:18 pm »
larger image,
its the "output connector" on the protech calipers from jaycar
the only difference I can see with the usb-mini-4p connector is it seems to have 2 grooves on the flat side, but it gives me somewhere to start, thank you
