Immediate correction is the only meaningful solution, you can't just speak generally and expect it to have any effect.
Exactly. If I make an error, it is not sufficient to tell me I made an error; I need specifics. "You know what it was" is not helpful.
Decades ago, I worked for a bit as an IT support person. I had spend a lot of extra time and effort to keep downtime to a minimum. The most annoying problem report I ever got was a post-it note on the door of a classroom with over a dozen machines: "One of the machines is broken. Please fix ASAP."
That kind of a bug report is evil. It is like finding a void in a haystack. It would take a lot of time and effort to go through every machine one by one, every feature/application one by one, to try and find out if a problem actually exists. Or it could just be a juvenile prank.
Dinosaurisms aren't evil, they're anachronistic bugs in interpersonal communications that can, at least in theory, be fixed. Treat them as such.
The reason I do not consider pencils dinosaurisms/anachronistic, is that there is a surprising amount of tactile feedback and visual resolution there that we cannot quite reach yet with digital devices. It's quick, nonvolatile, and efficient. Gel ink pen contrast is superb, and using it on top of pencil allows removing some of the pencil marks with careful eraser use. But when I have the sketch outlined or I get a mental picture of what it should look like, I do like to do an electronic, cleaned-up version, for reference use (if there is any).
For example, here is a diagram of when a spherical cap will tip over:
The marked point is the center of mass, and Ω is the solid angle from center of mass to contact point when the hemisphere would tip, and therefore the ratio of Ω to 4π describes the probability that the shape dropping so slowly it does not bounce, to a flat horizontal surface with zero angular velocity in an uniform random orientation, will end up tipping face flat on the surface. This I sketched first on paper, and this is the archival version (with accompanying text and description omitted). It's an SVG file, so infinitely scalable, and only 2k in size.
