Author Topic: Can be cheap DC/DC bricks used to power gate driver ?  (Read 788 times)
Offline MiyukiTopic starter
  • Country: cz
    • Me on youtube
« on: March 19, 2020, 05:33:51 pm »
Hi folks,
just a quick question, will common DC/DC brick work reliable as insulated gate power ?
They commonly dont have much specifications about them. Just DC voltage and some vague capacity.
Will they work with 400V transients at output side / high side driver ?
Online wraper
  • Country: lv
Re: Can be cheap DC/DC bricks used to power gate driver ?
« Reply #1 on: March 19, 2020, 05:45:25 pm »
They will work as power source for gate driver but not as gate driver itself.
Look at isolation voltage spec. Also if there is high isolation capacitance between primary and secondary side, it may be troublesome in some applications.
  • Country: cz
    • Me on youtube
« Reply #2 on: March 19, 2020, 06:10:15 pm »
DC/DC bricks designed for gate driving applications have CMTI ratings. Usually specified in kV/us or V/ns.
Oh thanks I see them in catalogue, but they are way more expensive than common ones :/
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: March 19, 2020, 06:30:50 pm »
Yes but...
- The above. Needs high immunity. Not hard to achieve, but if it's not rated, who knows?  Also, if you're using GaN, I would definitely want to see a rating, since the dV/dt is just so high.
- Isolation is usually poor, functional 1kV for example.  This may be technically adequate, but it may also lead to poor reliability versus a proper reinforced barrier.
Expect to pay more for parts with these ratings, or by solving it yourself with a discrete supply (and probably custom magnetics).
Seven Transistor Labs, LLC
  • Country: cz
    • Me on youtube
« Reply #4 on: March 19, 2020, 07:19:48 pm »
I dont want to use something exotic like GaN, but even today IGBTs can switch pretty fast (like that Infineon H5 ones can get over 20 V/ns)
I wanted to avoid discrete supply, that is why I asked, but still want to keep it cheap
If discrete supply will be only reasonable way, I still want to avoid custom magnetic if possible
As I look to general purpose ones without immunity they tend to have 5 to 10 times higher capacity between sides
Online wraper
  • Country: lv
« Reply #5 on: March 19, 2020, 07:33:18 pm »
The question is, do you really need it to begin with? What is particular application? Half-bridge gate driver with bootstrap might work just fine without any shenanigans.
  • Country: cz
    • Me on youtube
« Reply #6 on: March 19, 2020, 07:46:29 pm »
wraper: At Half-bridge it is simple, but with buck can be a problem and things like three level inverter ...
