I have floating a HV circuit (transformer 2200V AC secondary) and a floating LV circuit (transformer 24V AC secondary), for which I would like to connect their floating grounds GND1 and GND2 together (image attached). Can this be done without defying any basic rule in physics or electronics?
If you're asking why I need this:
The LV circuit will supply an opto-isolated IC (with 4kVpeak isolation) which allows voltage measurement through a resistor voltage divider in the floating HV circuit. A common ground is thus required.
