Sorry my bad I meant IEC 61000-4-6
Ok, some more context here.
So I know that common mode choke is used primarily for passing conducted emissions. We only have linear regulators so it's not a issue for us.
The problem which we are facing is with conducted susceptibility were we are having drifting in our sensor reading and also random keypresses on our membrane keypad if the de-bounce delay is low.
Do not understand discussion of x/y caps for radiated immunity tests.
Thing I know is that we need to add common mode and differential mode filter to remove all the the noise. For differential mode noise we are adding two ferrite beads on 24+ anf GND with capacitor in between hence forming a LC filter.
Now for common mode noise we know that we need a common mode choke. But all the examples and the literature I have about the common mode choke is with respect to AC mains supply and not much information for DC supply. The main issue we are having is with the safety capacitor.
As we are not working with mains voltages do we need safety capacitors or we can work with generic appropriately voltage rated capacitors?
