Electronics => Projects, Designs, and Technical Stuff => Topic started by: Yansi on May 27, 2018, 01:43:35 pm
Title: Can sb. please translate this piece of dtsh from Japanese?
Post by: Yansi on May 27, 2018, 01:43:35 pm
could somebody please translate this piece of datasheet from Japanese?
(https://www.eevblog.com/forum/projects/can-sb-please-translate-this-piece-of-dtsh-from-japanese/?action=dlattach;attach=442441;image)
Thank you !
//EDIT: Tried OCR a few times using different tools, but not much luck. Only found out the output is clipped sinewave. That was the only interesting result of translation using OCR. Arrrr..!
Title: Re: Can sb. please translate this piece of dtsh from Japanese?
Post by: gamalot on May 27, 2018, 02:35:45 pm
Hope this helps.  :)
Post by: Yansi on May 27, 2018, 02:45:14 pm
That was actually of a bit more help, than that cheeky bitching words cleaningOut's. Thanks.
You know cleaningOut, if you do not want to help, you can always just GTFO. No need to be cheeky, especially if you do not know what exactly I do need it for. I do not owe you anything.
