I'm trying to choose a power connector. Any recommendations?
- 24VDC, 2A max.
- 2 pins (V+ and Gnd)
- Cheap is good.
- PCB mounted, right-angle, will poke through a plastic housing but does not have to be mechanically held onto the plastic.
- Must have some sort of clip or lock, cannot be pulled straight out.
- Typical "barrel" power connectors are therefore no good.
