Hi!
I'm designing my first triac project, I have knowladge about main safety and triac's but just on a schoolar and theorethical basis.
I repaired many times defective device where triac's are bad, but never designed a solid state driver with a triac.
Im using a moc3021 opto and a BT139 triac.
I wanna have the ability to drive inductive load.
That would mean, I have to design a snoober circuit too.
My main problems are:
I saw many schematics on the net, where the designer connect the load between A1 of the triac and main plug.
Then I also saw ( more times I assume ) where the designer connect the load between A2 and the main plug.
If I remember me correctly from my school days, I've learned to connect the load between A2 and the main plug.
Like here on this page:
https://bestengineeringprojects.com/ac-motor-speed-controller-circuit-using-microcontroller/I see the designer put the motor on the MT2 side.
For me this is correct, but what about all the other project, where the motor is sitting on the MT1 side?
This is really confusing me.
Thanks for any explanatin and help me to understanding this.
