hello everyone.
This will be my first post on a new project I am staring. Last week in the datacenter at work we had both of our Big 3 phase UPS die. The great this is I got them both to take apart and play with, But the big score it the batteries in them they just replaced in August 2015. The One UPS had 40 SLA1161
http://www.mrsolar.com/content/pdf/Interstate/SLA1161.pdf and the other had 72 HR-12120W
http://www.csb-battery.com/upfiles/dow01461118859.pdf all new in the last 8 months.
Photos of the Batteries and the 2 units will be in this dropbox link
https://www.dropbox.com/sh/c16gdww2x0u7xod/AABBi1WsPnQEtl3Th2ERNUXYa?dl=0So my plan is to build 28 banks of batteries 4 batteries each at 48V. This will give me 18 banks of the HR-12120W batteries and 10 banks of the SLA1161 batteries. What is am wanting is to monitor voltage and temp of each battery and on a per bank I want voltage and current. With a over all system voltage and current.
I had some ideas on how to do this
First was to run a cat5 cable to each battery bank connect the first 5 wires to the -+ of each batter so I can start at ground and work my up each batter to get voltage of each battery and the entire set over all voltage. then add in a current shut in on the negative and use one more withe to read current. this leaves me 2 wires to send a 5vdc and a one-wire buss and use come ds18b20 sensors on each battery. once having all of this built build out a big mux to read all of these sensors off a pi or arduino.
second idea is cheep arduino board for each bank get all my voltage, current and temp at a bank level and then query each arduino over a i2c buss from a raspberry pi as a master to collect the data and put in some type of database to look at over web.
some other ideas i think would be cool to add to each bank is a on/off mosfet so I can shut off each bank and read voltage under no load or stop charging and other things. this is something simple to add in to the end product for not much extra. I think on my scale this will work out well because pulling 100A 4800W over 28 banks of batteries will pull less then 4A each bank and simple to-220 mosfet or 2 will work well if i use a low RDS sub 20m? to keep loss down.
What I would like to know is there any products/projects out there that does this? or any input on how to make some thing of this scale. I will probably make both ideas above just to get a idea of what it will look like on a 2 or 3 bank system and get the ideas flowing for later revisions.
This new bank of batteries will get added to my other stash of equipment I have been collecting over the years to have a off grid house. I currently have 6 grape solar GS-S-250-Fab5 panels not installed yet with 2 Morningstar TS-MPPT-60 charge controllers. this will be my solar input to charge and maintain my banks. I have some cheep china gridetie inverts 300W each x4 that I want to use to push power back to grid when I have a excess solar power. I also will have 2 modified APC SUA3000 UPS like what was done in this video series by knurlgnar24
https://www.youtube.com/playlist?list=PLdImEedbzeWSpxQpQpqnFEKa5NKYXXe-V one ups had double transformer and upgraded to 8 FB4710 mosfets on each side of the H bridge.
I will have more photos of things over the next few night as i take them apart and unload them in to the garage.
