Author Topic: Can you mount TO-3 transistors on flat heatsinks?  (Read 10082 times)
Offline heatbreakTopic starter
« on: January 13, 2016, 02:33:51 am »
Hi there,
    It seems that it's easier and cheaper to get flat heatsinks (you know those used to mount TO-220s).  Is there anyway to mount TO-3 parts onto those flat heatsinks?  I thought about mounting a bank of them onto some kind of L-bracket and then mount the L-bracket onto the heatsink.  Would that work?  Would that give the same heat transfer as if you mount them directly onto the heatsinks?
Thanks
Online Ian.M
Re: Can you mount TO-3 transistors on flat heatsinks?
« Reply #1 on: January 13, 2016, 02:41:05 am »
Errr. . .
TO-3 are designed for external mounting to a flat heatsink surface.  You need a 27mm flat between the fins and simply drill clearance holes for the leads.
Offline retrolefty
« Reply #2 on: January 13, 2016, 03:22:33 am »
 There sure is, and it works much better then on curved heatsinks.   :-DD
Offline lwatts666
« Reply #3 on: January 13, 2016, 05:45:45 am »
I assume you mean one side fully covered with fins, the other side completely flat.
The angle bracket solution can work, but it introduces additional thermal resistance between the TO-3 and the heatsink, and hence gives greater die temperature for a given power dissipation. Depending on the situation this may become a problem.
A suitably thick custom drilled bracket, additional mounting screws, extra heat transfer compound, assembly, etc will probably cost more than the savings made in the heat sink.
I've seen it done, and done it myself, when mechanical constraints overrode the additional costs involved.
Preference should be with a heat sink designed for TO-3's if possible
Offline station240
« Reply #4 on: January 13, 2016, 09:40:51 am »
It's been done before, a common 100W* amplifier kit in Australia had 4 TO-3's mounted to an L bracket, then the bracket mounted to the heatsink. Kit came without the heatsink, so you could select/supply one to suit.
* there was also a 50W version with only half the output transistors.
Offline Siwastaja
« Reply #5 on: January 13, 2016, 10:05:48 am »
L brackets are used quite often. You can even sandwich the bracket to PCB for direct PCB mounting of the TO-3 packages. You need to screw them down and tighten before soldering the leads. This construction limits the L material thickness so much that using copper instead of aluminium is highly recommended. In any case, you need to do the thermal analysis and an extra L bracket complicates it a bit.
Online Ian.M
« Reply #6 on: January 13, 2016, 11:04:30 am »
You'd do better simply to get TO-247 package parts in the first place.  However if you *MUST* mount a TO-3 to a flat base, fully finned heatsink, and you cant afford a heavy top hat heat spreader bracket or milled interface plate, consider drilling two extra holes outside the outline so you can thread the B and E wires back through from the fin side.  You will need to be really careful to align the B and E leg holes with a gap between fins, and wont be able to fit any ferrite beads or small caps right at the pins that may be needed for stability.
Offline Pjotr
« Reply #7 on: January 13, 2016, 01:50:53 pm »
That is not a good idea. Many audio amps are constructed that way. I have repaired many due to loose solder joints over time. The solder joints cannot stand the stress due to thermal expansion of the TO3 pins. If you do so, always solder the TO3 pins with a separate wire to the PCB to catch thermal expansion.
Offline rdl
« Reply #8 on: January 13, 2016, 06:08:32 pm »
It probably doesn't matter as long as the heatsink has enough surface area and the transistor is bolted down with sufficiently good contact.
The HP 3610 power supply uses heatsinks where the fins are vertical on the back of the case and the TO-3 transistors are mounted horizontally (pins down) on a "shelf" that projects into the case (see EEVblog #166, fast forward to about the 12 minute mark).
Offline pmbrunelle
  • lost mech. guy
« Reply #9 on: January 14, 2016, 02:09:40 am »
This is good to know!
I wonder if you can bend the leads in a Z-shape first, and then soldering to a PCB might be reliable.
« Reply #10 on: January 14, 2016, 03:27:01 am »
Looks the "L-Bracket" and the heatsink are one single piece on the HP-3610.  That situation is similar to the earlier Hafler audio amps.  We were all discussing the situation where you have two separate heatsinks: L-Bracket and a flat, finned, heatsink and the two is joined together with screws and heatsink compound.
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #11 on: January 14, 2016, 06:23:21 am »
How about mounting the TO-3 packages 'properly' to a suitable heatsink for the required application - and running simple flying lead pigtails back to the PCB ?
This has been done countless times in the past and doesn't seem to have any downside.
Don't ask a question if you aren't willing to listen to the answer.
Offline dom0
« Reply #12 on: January 14, 2016, 09:34:15 am »
Lead inductance.
Why not just use TO-247 AKA TO-3P (because it achieves very similar thermal performance as TO-3)?
Offline SL4P
« Reply #13 on: January 14, 2016, 09:42:02 am »
Lead inductance
Sorry, I'm didn't pick up the RF/HF requirement...  possibly routing the leads, or individual shielding as needed.
I'm not experienced in that area.
Offline janoc
« Reply #14 on: January 15, 2016, 03:57:49 pm »
Depends on the application but most places where TO-3s are used the lead inductance is not really an issue - audio amps, power supplies, etc.
All low frequency stuff. The parasitics can be dealt with by keeping the wires as short as possible - i.e. don't tread the wires to your PA transistors all over the case!
Offline Kleinstein
« Reply #15 on: January 15, 2016, 04:14:30 pm »
Even though frequencies are low in DC supplies and Audio amplifiers, the output impedance is low and loop bandwidth is the critical limit, not the actual signal frequency. So parasitic inductance in the 100 nH range can matter even in a DC supply. However modern supplies prefer TO247 or similar over the old TO3 style.
Offline Pjotr
« Reply #16 on: January 15, 2016, 06:02:06 pm »
GBP of a PSU is usally very small due to the output caps. Otherwise sense wires do not work. It is different with audio amps indeed. But even there, GBP is no more than 10MHz at best.
Offline dom0
« Reply #17 on: January 15, 2016, 06:07:48 pm »
Of the whole amplifier... not of the output stage.
The classic HP topology is also somewhat prone to RF oscillations, due to the high voltage and current gain in the pass element. With high speed MOSFET devices those things can oscillate at over 100 MHz. Loop speed mainly depends on choice of output capacitance => low output capacitance => need for dynamic regulation => fast loop.
« Last Edit: January 15, 2016, 06:10:06 pm by dom0 »
