Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Embedded computer using Allwinner H3 - Power management
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Embedded computer using Allwinner H3 - Power management (Read 1711 times)
dingari
Contributor
on:
July 26, 2016, 11:51:05 am »
Hi, my team is staring work on an embedded computer using the Allwinner H3 SOC and we have a few questions to get out of the way regarding the power management.
I've looked at the FriendlyArm NanoPi (both NEO and M1) and OrangePi Plus schematics (all using Allwinner H3), and they seem to be using seperate regulator ICs for the different voltage rails. While the CHIP computer (Allwinner R8) is using a single AXP209 PMU IC (including a battery charger).
My product will run from a battery, so I'm leaning more toward the single PMU IC route. I've found
AXP209
AXP221
AXP223
and
AXP809
, which all seem to be fitting. I've not looked too much into the differences, but the AXP221 or 223 seem appropriate at first glance. The AXP809 is also much more expensive than the others.
Is this a cost / size / availability tradeoff? Or is there another reason the H3 boards all utilize seperate ICs?
Also, what WiFi + Bluetooth chip would you recommend?
NanoPi M1 schematic:
http://wiki.friendlyarm.com/wiki/images/d/d8/NanoPi-M1-1603-Schematic.pdf
NanoPi NEO schematic:
http://wiki.friendlyarm.com/wiki/images/a/aa/NanoPi-NEO-1606-Schematic.pdf
OrangePi Plus schematic:
http://pan.baidu.com/s/1bnppzv5
CHIP schematic:
https://github.com/NextThingCo/CHIP-Hardware/blob/master/CHIP%5Bv1_0%5D/CHIP_v1_0_SCHEMATIC_20151203.pdf
Last Edit: July 26, 2016, 12:12:26 pm by dingari
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
