Probably the same florescent tubes that were used for germicidal lamps and for erasing EPROMS. Those tubes had quartz envelopes instead of glass so the output contained huge amounts of UV-C, unlike regular glass tubes which blocked most of the UV-C.
Exactly. Medical "germicidal lamp" is a must have device. First, it can erase EPROM (the spectrum peak is just right, 253.7 nm). Second, it can heal a skin wound. Typically, a minor injure is self-healing. But sometimes not, and in that case clean the wound and expose it to UV-C light. For short time, less than a minute. Just use a mask to prevent a healthy skin around the wound from exposure. For me, it always worked excellent.
As mentioned above, UV curing lamps are completely different to germicidal lamps. They emit much longer, lower energy/frequency radiation, typically peaking around 360nm, which is a lot safer.
I've never heard of germicidal lamps being used on wounds. UV will kill bacteria, but also healthy tissue and can cause cancer.
Have there been any medical studies?
I would stick to ordinary antiseptic. It also damages healthy tissue, but at least it's not carcinogenic.
"Using three different cell lines—adult human skin keratinocytes, human foreskin fibroblasts, and mouse embryonic fibroblasts—the researchers found that the use of these UV emitting devices for just one 20-minute session led to between 20 and 30 percent cell death, while three consecutive 20-minute exposures caused between 65 and 70 percent of the exposed cells to die."
This is odd because you'd think people would notice the skin death on your fingers if you regularly cure your nails?
Perhaps it's because the skin cells on the surface are already dead?
I admit, I haven't read the entire study. If they've just tested it on living tissue, it doesn't prove the long wavelengths used to cure nail gel, cause cancer. Did they find out how much of the UV radiation is absorbed by the top layer of dead skin and take that into account? I would suspect a significant amount is absorbed, before it gets to living tissue.
warning, sugar can cause diabetes, salt and beer can cause kidney failure, esp beer can cause mental disorder... bla bla bla... who give a rat arse?
Tons of people who care about their health.
There is a lot of unfounded panic over health. If you're worried, just wear glasses with a UV filter and sunscreen, when dealing with UV light. Note sunscreen is only been tested to block UVA and UVB, not UVC, and is probably no good to protect against UV from germicidal lamps and arc welding.
