I'm designing a 24V regulated battery operated power bus with multiple connectors for various devices that are hot-plugged into the 24V bus. I'm looking to incorporate MOSFET switches at each socket to monitor current, control power delivery and enable soft start when a device is plugged in.
My challenge is to detect when a connector is plugged into the socket. Since the plug and socket of the external devices adhere to standardized configurations, I can't add an extra pin for plug-in detection.
Is there a method or IC that can keep the MOSFET in the ohmic region until a load is detected, at which point it would initiate a soft start?
I’m open to all ideas here and any suggestions are greatly appreciated!
Owen
