Dear colleagues,
At the moment I work on designing a device and I can't understand which principle/rules should be used to select a DC/DC and LDO for power supplying digital ICs. I have the following ICs - 6 sensor with I2C bus, GNSS on a separate pcb, ARM STM32, display control, display backlight, LAN (Ethernet with LAN IC 10/100 Base-T).
All ICs are powered from 3.3 volts. The two additinal sensors are powered by 5 volts. The device will be powered from general external AC/DC 120-220/5V, backup power from 12 volts.
My vision is the following: 12 volts step down to 5 volts using a low-noise DC-DC. Then 5 volts step down to 3.3 volts using a low-noise LDO. I need to power 11 ICs so that there is minimal impact on all 11 ICs between each other and I would like to pass EMC/EMI Testing and Certification. Also, I don't understand if I need to use a Ripple Blocker LDO for each IC? When laying out a PCB, how often should ground layers be used? Device will not be produced in the millions and I would not like to save on the components.
This is the voltage and current consumption of some ICs: 5 volts-0.5A, 3.3 volts-0.05A, 3.3 volts-0.07A, 3.3 volts-0.08A, 3.3 volts-0.1A.
I am considering using the DC-DC TPS62912, LDO TPS7Axx family or MIC94325/45/55 family.
Do I need to use one LDO or several to power all the consumers like ARM and other analog/digital ICs? Does it make sense to use a more advanced LDO from the TPS7Axx family?
How important is it to use an advanced LDO from the TPS7Axx family or can I use, for example, the MIC94325/45/55 family?
Does it make sense to power the sensors from multiple TPS7Axx or MIC94325/45/55 LDOs, or is it enough to "sandwich" 0.01uF, 0.1uF, and 10uF capacitors near the power pins of each sensor?
What about powering the digital ICs that are responsible for power/backlight and display control, or is it enough to "sandwich" 0.01uF, 0.1uF, and 10uF capacitors near the power pins of each digital ICs?
Detailed information about Ripple Blocker LDO - digikey.com/es/product-highlight/m/micrel/ripple-blocker
I would be thankful if you would help me with your advice and recommendations.
Best wishes
Georg
