Author Topic: Capacitor for non isolated "capacitor" power supply is X cap required if fused?  (Read 1123 times)
Offline JesterTopic starter
For a circuit like this (assuming UL approval is required), is a X-rated safety cap required if a series fuse is before the circuit?
The circuit is completely inaccessible to the user, so isolation is not required.
Edit:         ——-  zener is 12V ——-
« Last Edit: April 20, 2019, 12:31:15 pm by Jester »
Offline coppercone2
won't a X cap take surges and stuff better?
Offline Gyro
There isn't actually a requirement to use a X cap in a capacitive dropper, in fact some capacitor manufacturers discourage it due to the thinner metallization and progressive capacitance loss (it needs to be rated rather higher than 400V though). You can have UL (flammability) without X rating. The onus is on the manufacturer (you in this case) to ensure that the entire circuit is safe, not just individual components.
Let's look at your circuit, as drawn. If they capacitor shorts (even briefly) then full mains current will flow. The 6V2 Zener will take the brunt of it and probably fry first, then the either the bridge or the NTC thermistor will blow (assuming the zener fails short).  Clearly protection is needed.
You also have the issue of mains spikes (even turn-on spikes at mains peak). The capacitor impedance will pass a nice predictable current on a 50/60Hz sine-wave. When you hit it with a fast edge, it will pass a great deal more current. If there's sufficient energy, it will start taking out parts, and a fuse won't be quick enough. You need a series resistor to limit these spikes. If you put, for example, a 330R resistor in series with the input, this will limit these spikes to less than 1A. With properly rated parts, the circuit can mop those up.
Now we come to the issue of the capacitor shorting again. The resistor will try to dissipate all the power between mains voltage and the 6V2 clamp. To overcome this you should make this resistor a flameproof fusible one. It will go open circuit cleanly and without fuss in these circumstances.
Yes, it would be advisable to fit a fused inlet too - the PCB might break or something come loose if dropped for instance, but you wouldn't normally expect it to act fast enough to open with a component fault, the fusible resistor will go first. You should pretty much always use a fuse at a mains input, it's the last line of defence.
P.S. Do you really mean an NTC thermistor there?
« Last Edit: April 20, 2019, 09:12:17 am by Gyro »
Best Regards, Chris
The following users thanked this post: Jester
Gyro,
Thanks for your insight.
The load current varies from about 1mA to as much as 80mA, the thermistor warms up enough to allow 80mA. The zener is actually 12V. Mains are 120V.
« Last Edit: April 20, 2019, 01:07:13 pm by Jester »
Offline Gyro
You're welcome.
Ouch, 80mA is a lot to be pulling on a capacitive dropper though, well over what most applications use it for. ... I think you're looking at around 8uF 2.5uF for that at 60Hz, if my maths is right, so you'd be looking at a motor-run Polypropylene film rather than an X cap anyway (probably the reason for your question).
I'd think twice, you will probably find that a small transformer based or off the shelf SMPS wall wart would be more compact, cheaper and more satisfactory.
« Last Edit: April 20, 2019, 02:56:21 pm by Gyro »
Best Regards, Chris
I put together a breadboard version yesterday with a 2u2 and an unspecified 100 Ohm NTC and was able to pull 80mA. I actually only need 80mA for 4 s per hour, with nominal current between 1 and 10 mA. I’m very space confined and an external wallwart is not an option. One of the LNK parts might end up being smaller, but then need additional filtering etc.
This is turning into one of those piece of cake to hmmm.... this is going to be tight scenarios.
I'm going to look at this part as a possible solution: https://www.mouser.com/ProductDetail/Power-Integrations/LNK3202D-TL?qs=%2Fha2pyFadugWa4O%252BeeNnoeocbir1MDK9Jh5bTXhWL2Nct%252B%252BMnPM7DA%3D%3D
If anyone has suggestions for a better approach I'm all ears.
« Last Edit: April 20, 2019, 05:11:20 pm by Jester »
