Hi All,
The audio bug has bitten me again and I am currently in the process of re-designing my pre-amp power supply. In my office there is a fair amount of common mode noise I would like to filter out, but having never used a common mode choke before and being a little bit lost with the right inductors to use, I would use some advice.
It is a linear +/-15VDC unit, I have already recycled some parts out of a washing machine for the Mains AC side of things (230V), including a chunky common mode choke and so far the output of the supply is 2-3x cleaner then my prior attempt, however I feel that more could be filtered out after the toroidal transformer which is about 22V AC ptp. The choke I pilfered likely isn't right for the job, but it was free
So my questions are:
* Should I use a low voltage choke after the transformer also?
* What value should the choke be to filter as much noise as possible.
* Please explain the selection of choke so that in future I can figure this out for myself
