Hi, i'm planning to design a proper USB charger this summer for use in my car . i'm some how a beginner.
some requirement/facts :
2A output (nominal). 2.5A Current Limited.
5.1V output.
Stable and reliable over temperature/time
Ambient temperature is about 50 Degree (circuit will be inside the dashboard. so no airflow and it's beside the heater).
startup delay .( 5Sec )
Sleep mode( On for 1 Hour after turning off the car)(detect using accessory power)
Low noise.
Undervoltage and Overvoltage(Is necessary ?) lockout
no overshoot
Also i don't have easy access to fancy parts such as USB Current limiters or new regulators.
I only have access to
locally available parts, including: LM2576 , LM2596 and LM2678. ( i can order other parts but i have to wait a month which i don't want. )
also it's more fun to use basic parts to do the job
Any suggestion on design ?
i will update this post with my design.
thanks for your help/comment/suggestion in advance.
(sorry for bad english
