Hi!
After watching Dave's video #600 about OP-amps, I started thinking about how you could invert a signal to "make it go zero".
If you have an inverting OP-amp connected to your AUX plug in your car, you could, theoretically cancel the noise.
It would be fun to test this out, so I guess I'm going to build one and test!
The problem is that if you speak, or listen to music, the OP-amp will also invert these signals.
So, how can you make the OP-amp invert just a specific signal (car noise), and not voices and music? Does is exist audio signal processors that could fix this?
