Author Topic: Case capacitive coupled to Vcc and GND  (Read 913 times)
Offline eTobeyTopic starter
  • Virtual Features for the SDS800XHD -> My website
    • Virtual feature script
« on: January 03, 2024, 09:50:12 am »
i wonder, if anyone knows what this coupling is for:
I would have thought, that just connecting it to GND would be good enough? Its the controller of an ebike motor.
Cheers,
Toby
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant."(Maxim Gorki)
SDS800X HD bugs/issues/workarounds (Updated 17. Feb. 2025)
Offline Ian.M
Re: Case capacitive coupled to Vcc and GND
« Reply #1 on: January 03, 2024, 10:03:39 am »
It provides RF grounding for EMI while avoiding any risk of current flowing via the mounting hole pads, possibly melting undersize ground tracks, if the negative feed to its power in terminal comes loose.
Offline magic
« Reply #2 on: January 03, 2024, 10:20:13 am »
This explains the AC coupling, but not the coupling to 50% of VCC rather than to GND.
Normally if GND is grounded, such connection would put 50% of VCC ripple on the case. Usually a cap is placed between the case and GND alone.
But this is a floating circuit, so maybe they figured that its average potential is constant and equal to the midpoint between BAT- and BAT+, hence such grounding.
Offline Ian.M
« Reply #3 on: January 03, 2024, 10:23:27 am »
... or they wanted it to work equally well (or at least equally poorly) for positive ground and negative ground vehicles.
« Last Edit: January 03, 2024, 10:25:49 am by Ian.M »
Offline wraper
  • Country: lv
« Reply #4 on: January 03, 2024, 10:23:45 am »
I've seen plenty of bad engineering to first assume that engineers had no clue what they were doing rather than it actually serving some valid purpose.
« Last Edit: January 03, 2024, 10:29:02 am by wraper »
Offline wraper
  • Country: lv
« Reply #5 on: January 03, 2024, 10:39:42 am »
On second thought this could potentially reduce EMI created by the circuit. However only if hardware is laid out in a quite specific way.
Offline magic
« Reply #6 on: January 03, 2024, 10:47:12 am »
Hmm, are e-bike batteries electrically connected to the frame like in cars? I assumed the whole thing would be floating.
Offline Ian.M
« Reply #7 on: January 03, 2024, 10:50:05 am »
Some cheap manufactures cant resist the temptation of using frame ground as return for low current accessories, even though its less than ideal from corrosion and reliability viewpoints.
