Hi we help develop a car diagnostic system . about 5 years back.
What you are looking at is just part of the story .. Car ignition varies from make / Model /year / engine size/ compression ratio / altitude / O2 % .. etc .
The ignition system is controlled by the central computer which measures about 8 sensors from the engine and fuel .
The pulse you are seeing is about what you will see . from a GP scope . be careful your scope is mains grounded ..
you have to use the diag plug with a loop back to tell the on board computer to output the correct signals .
and you need the the manufactures data for you Car as every model differs .
You need to use the correct Diag equipment .
The signal you are seeing will not be of any use as this is only 1 fire pulse without the time from TDC -8 -10 deg.
Have fun
BTW if you really like your scope Don't use it on a car ignition system without Isolated clap over probe .
Update .. 2 quick details ..
1 . remove the plug from the engine connect it to the lead and rest the case of plug on chase on engine ground.
if there is a spark its good. Clean all plugs.
2 60% of engine problems are caused by the immobilizer system .. check first
