Author Topic: CC or CV power supply for an induction heater?  (Read 220 times)
Offline drummerdimitriTopic starter
  • Country: lb
« on: December 28, 2024, 05:51:09 pm »
I bought a 1000W 20A 48V DC induction heater from Aliexpress and need to buy a power supply for the unit.
Would I be better off with a CC or CV design? I'm afraid that a CV unit might get overloaded if a very large piece of steel is inserted into the coil and a CC unit would just limit the power output and not trip the power supply.
That being said, I know that these units need to get 48V immediately and not a slow voltage ramp up since it needs a kick to get them to start oscillating.
Either way, I will be installing a switch on one of the wires so that I can give the power supply time to get to the appropriate voltage before turning the unit on.
What are your thoughts on this?
« Last Edit: December 28, 2024, 05:53:12 pm by drummerdimitri »
Offline Vovk_Z
  • Country: ua
Re: CC or CV power supply for an induction heater?
« Reply #1 on: December 31, 2024, 10:06:13 pm »
I'm nor well known with induction heaters but unlikely it needs to be CC powered.
