What is your 'de-rating' (setting 'safer' than data sheet) experience in setting 4-wires SPI master clock frequency?
The sensor data sheet says 17MHz. Factory support person says 2 to 10MHz. The demo board (which we do not have) is 7_5MHz in driver software (presume 7.5MHz).
MCU and sensor within 1.5 inches (50mm). Only MCU and one sensor, 3 volts push-pull I/O. No long wiring to multiple sensors. Cell life limited. We like transfer as fast as safely possible so devices can sleep soonest.
Many thanks
