Hi all.
I have a HP 5065A Rubidium standard that I'm fixing up and I need to replace all the wet tantalum capacitors as some have just started to leak.
They are 100uF, 30V Vishay 109D parts, and their price is the usual 'left arm and firstborn son' on Digikey and Mouser...
So, I plan to replace them all with Vishay 138 AML series axial electrolytic caps.
My question is, what's the general rule of thumb for this sort of thing? These seem to be basically all power supply caps around the place, so nothing too critical.
I've seen some say you should double the capacitance, others say an 0.1uF ceramic cap should be connected in parallel, etc etc.
For reference, the 109D caps have the following specs:
https://www.vishay.com/docs/40023/109d.pdfESR: 6
ESL: 40
DC Leakage: 2uA
Ripple Current: 410mA
A 100uF, 40V 138AML cap has the following specs:
https://www.vishay.com/docs/28332/138aml.pdfESR: 1.6
ESL: 0.9
DC Leakage: 12uA
Ripple Current: 180mA
Obviously, going up in voltage rating will give better specs, to the point package size becomes an issue, and a 330uF, 40V electro is better in all the above specs besides leakage at 30uA.
Or maybe I'm just looking too far into this for basic power filtering caps.
